4 EGT's on an M800
Tue Sep 22, 2009 2:02 pm
by garychios
I just cant figure out how you wire in 4 EGT's on the M800. The pin outs mentioned are no where to be found.
Re: 4 EGT's on an M800
Tue Sep 22, 2009 3:00 pm
by RossB
You will need to use thermocouple amplifiers and you can wire them in to any AT or AV input. When you say that "the pin outs mentioned are no where to be found" which pin outs are you referring to and where were they mentioned?
MoTeC Drawing # A03 refers to the Thermocouple Amplifier.
Wed Sep 23, 2009 10:31 am
by garychios
What would be the best course of action to do this? E888?
Also, the pin outs are mentioned in the software, but I might have mis-read it.
Wed Sep 23, 2009 3:44 pm
by MarkMc
Four EGT thermocouple amps will be cheaper than an E888 but you really have to ask yourself if you are going to end up adding more sensors in the future. With an E888 you get the 8 thermocouple inputs, 8 other Analogue channels and four digital. It really depends on how "full" your ECU is at the moment.
Fri Sep 25, 2009 8:39 am
by garychios
Where can I get thermocouple amplifiers. Or what is recommended?
Fri Sep 25, 2009 9:08 am
by RossB
You can get them from a MoTeC dealer. MoTeC part number 58008.
Fri Sep 25, 2009 10:38 pm
by garychios
Thank you. I missed that in the catalogue.
