Setting up Driver Warning
I have wired up my CEL to IGN 4 as Driver Warning but I cannot see the "Warning Alarms" function under "Functions". How do I configure and use Driver Warning?
JR
JR
The official support forum for MoTeC products
https://forum.motec.com.au/
RossB wrote:You set this up under Ignition Output Functions. Use function 108 Driver Warning. Then set the parameters for the correct logic.
RossB wrote: You can choose to include Diagnostic Errors which will include value set in your Input Setup (Diag Lo / Diag Hi) or just to have a warning based on the warning values configured in the input setup (Warn Hi / Warn Lo). Diagnostic Errors will include all other errors for Ref/sync etc.
