Dash and ECU manager run together
I don't know where to put this question.
I am configuring a bike fitted with M800 and ADL, connected together via CAN, and to the PC with a parallel-CAN cable. For initial startup and setting, I have to switch from ECU manager to Dash manager. Each time, I must close the connection, and reopen it on the other software.
Is there a way to have both software active and connected to their respective device, on the same PC, with only one CAN cable?
What will append if I use two UTC cables on one PC, connected to the CAN bus ? Will each software detect and use them correctly? Obviously, the UTC should have different CAN ID.
Angelo
Angelo
