Electron Speed: Sadly I was not aware of A key function. Thank You
A post on EFI 101 prompted me to pose this question (mostly because I did not fully understand the response in the post). I'd appreciate any insight as to what was being suggested and more importantly how to implement it using the M800. The post is
http://efi101.com/forum/viewtopic.php?t=3558&start=20 and specifically is:
We were in EMS row at the PRI Show, one booth from Motec.
I asked the brillant Shane T. how the ADD the correct calibration for coil control.
His method was to use Battery comp. as one of the Axis, the other was
a created AUX channel, the other Axis.
The AUX #8 is now a combination of two objects (RPM AND MAP).
Thus coil charge is based on 3 axis control.
Items are supported to include, Voltage, Load, Duty Cycle.
Quite clever, Shane.
Lance
