basemap request - 3SGTE (MR2)
Postby mr2andy on Thu Sep 03, 2009 12:55 am
Will anyone be able to supply a basemap for 93 Toyota MR2 Turbo: Mod detail as below
M800
T3/T4 Turbo
OEM distributor with magnetic ref/sync sensors
GM 3 Bar map sensor
MSD 6AL-2 CDI ignition
supra 550 injector (planning on upgrading to 1000cc borsch saturated injector)
Cheers :)
Andy
mr2andy
Re: basemap request - 3SGTE (MR2)
Postby mr2andy on Fri Sep 04, 2009 12:57 am
Guys..
I'm currently running another EMS and is setup at batch firing. If I can calculate the millisec of the injector pulse time on the current fuel map then multiply by 2(since it is currently batch firing and it will be sequential using m800) , Will that be a good idea?
Cheers
mr2andy
Postby mr2andy on Wed Sep 09, 2009 7:40 am
Anyone?
Motec?
Help?
mr2andy
Postby RossB on Wed Sep 09, 2009 1:43 pm
I have attached a start file for a 3SG Turbo which should help you to get started. If you are converting from batch fire to sequential doubling the injection duration is a good place to start from. If you are converting from one system to another you need to also make sure that all of the same compensations are being applied.
3sg turbo start.e23
(24.54 KiB) Downloaded 1572 times
Postby Toyota1968 on Tue Feb 26, 2013 7:52 am
.....just so I can find this again
Toyota1968
