rev limiter discussion
I was recently provoked into thought by someone claiming that they were having problems with their Motec pit speed limiting strategy (similar to the rev limiter strategy) breaking crankshafts. Presumably an uneven firing was twisting the cranks and causing bearing damage and resulting in crank failure.
Without doing a lot of testing (and potential crank breaking) is there any accumulated knowledge about setting up limiters with an eye toward minimizing damage?
For example
spark versus fuel cut?
Randomizers set at 75 (near random) or 189 (more Bosch like consistent pattern of cylinders)?
Methods of preempting cuts with ignition timing or coil dwell? Easy for a revlimiter but tougher for something like TC or pit lane speed limiting.
What are the big knobs in this game?
thanks for the thoughts,
Eric Schieb
For example
Eric Schieb
