m600 with ls1 coil
Sat Aug 22, 2009 7:39 am
by SniperxXx
hi guys i need help
i have m600 motec with 6 ls1 coil without igniter for 2jz engine so wich taip of igntion i have to us ?
i her thar is msd but i dont no wich one thanks for help
Re: m600 with ls1 coil
Sat Aug 22, 2009 4:07 pm
by skyline_stu
Hi, I take it that this is a non turbo engine with a dizzy fitted?. If this is the case, you can use a single LS1 coil triggered straight from the ECU, as the coil has an inbuilt ignitor. Check the documents page on the website, Download the Denso coil M32 drawing.
Hope this helps
Sun Sep 13, 2009 4:43 am
by SniperxXx
thanks skyline but the ls1 coil is Denso with 4 pins i need igntion between the motec and the 6 coil ?
thanks for help....
Mon Sep 14, 2009 9:43 am
by RossB
Set the ignition type to "1". The number of coils needs to be set to "6" if you have the coils wired sequentially or "3" if you have them wired as wasted spark.
Use the following values for your Dwell Table:
- Code: Select all
Volts Bat Comp (msec)
8 7.7
9 6.2
10 5.1
11 4.4
12 3.9
13 3.5
14 3.2
15 2.9
