How to setup REF/Sync Mode For Honda K20A
Postby Fueltank-Tai on Fri Aug 21, 2009 3:33 pm
Hi :
Anyone can help me to setup Ref/Sync Mode for Honda K20A.
I know Crank 24+2. Cam 4+1 . Thank you so much.
Fueltank-Tai
Re: How to setup REF/Sync Mode For Honda K20A
Postby OmarK on Fri Aug 21, 2009 3:50 pm
The Ref/Sync Mode for a Honda K20A is Mode 29. In Ref/Sync Setup you can press "F1" for more information on this mode. Cheers.
OmarK
Postby Fueltank-Tai on Fri Aug 21, 2009 6:54 pm
Thank you Omark . But i saw the mode 29 is Crank 12+1 Cam 4+1. Is it ok? Thank you so much.
Fueltank-Tai
Postby RossB on Mon Aug 24, 2009 9:44 am
This is the correct mode for the K20A, not sure where you get 24+2 from? It should have 12+1 on the crank and 4+1 on the Exhaust Cam. The Inlet Cam has 4 evenly spaced teeth and needs to be wired to a digital input for Cam Position Measurement.
