How to pick up RPM?
Fri Aug 21, 2009 2:03 pm
by Pascal
I have one Chevrolet Epica 2.0 AT. Need to put into M800 somehow RPM. Cant install another choper disk or sensor. My idea is from injectors, to pick up there signal and wire it somehow to M800. Anyone have some expirience? ECU is NOT used to control engine, srandard ECU is running engine. I just need few data's like RPM, brake switch, speed and G-sensor from DDA and thats it.
many thanks!
Re: How to pick up RPM?
Fri Aug 21, 2009 4:55 pm
by John Reed
If the timing pattern is supported, the easiest way would be to just share the stock crank trigger signal with both the ECU controlling the engine and the MoTeC.
Fri Aug 21, 2009 6:33 pm
by Pascal
Problem is that must not come yellow engine problem light on the dash so i am trying to avoid to touch cranck sensor. But maybe can try if there is no other better solution. At moment trying to get idea what is possibly best idea.
Many thanks
Sat Aug 22, 2009 12:36 am
by John Reed
Pascal wrote:Problem is that must not come yellow engine problem light on the dash so i am trying to avoid to touch cranck sensor. But maybe can try if there is no other better solution. At moment trying to get idea what is possibly best idea.
Many thanks
You should be able to share the signal without causing check engine light. I have done it many many times, on different cars.
