Laptop losing ECU connection after starting
I have a slight problem with my ECU connection.
I am using an M800 ECU, to an Aprilia SXV 550, with my own wiring loom and relay bank.
The problem: I am yet to get the engine actually running as i am waiting on a sync sensor, but, when I press the start button and crank the engine over for a second or two, it cranks fine but then when I stop a message comes up on my laptop saying the ECU is not connected. Then, to bring back the ECU screen with all my sensors and stuff I have to unplug the usb cable and then plug it back in. Before I crank, the Motec screen is fine, and all sensors give readings, and after I reset the usb all is fine. It just loses connection when I stop cranking.
Have I got a wire missing, or in wrong? Or is it because of a sensor error, such as sync or lambda? Or perhaps is it just because I am not actually ticking the engine over?
As I said, I have not actually started the engine yet, and am waiting on a sync sensor, but just happened to notice this when testing all my systems.
Thanks in advance
Thanks in advance
