A few questions on Setup for a MKIV supra.
This is on a stroked 3.2 liter 2JZ-GTE. The cylinder head being used is a VVT-i and the throttle body being used is a large 85mm DBW unit from a Lexus IS-F.
My M800 has DBW, Cam control Lamdba, 1MB logging and advanced functions enabled. I noticed in the sync/ref sensor setup that the IS300 is an OEM option. This vehicle uses the same 36 minus 2 for the reference. The sync is also the same with 3 teeth. Both these sensors are magnetic reference. My question here is when you select this setting do I still have to figure out the magnetic reference sensor thershold values?
The VVT-i control from the OEM ecu is via 2 wire. Having looked at the control with the OEM ecu, it appears that the OEM ecu provides the power and the duty cycled ground. Should I use cam control with one wire or two wires? Simply trying to conserve my outputs.
I was also planning on using six 1000cc fuel injectors in the port and injector output #7 to control two 1000cc methanol injectors in the charge pipe. These two injectors will not spray at a timed event like the main six will. Should I use the Aux output options and select RPM and MAP as my X and Y respectively in my axis setup and built a table to control them? I don't think I need Lambda feedback on them. Or do you have another option? My unit doesn't have the 10/12 cylinder option enabled.
I'm also unsure about the fuel pressure control via PWM/PID. I noticed this as an option in the output function setup. Do you use a solid state relay to control the fuel pump using the fuel pressure sensor as a reference? Do you ditch the fuel pressure regulator altogether and use an orifice to restrict the flow back to the tank?
Also noticed that ignition on can be used as an input. This states that would be the case of having the ecu powered at all times. How much current would that consume? It this used as a battery backup function like OEMs use?
BTW, thanks in advance for the time to respond to my billion questions. The unit seems like a lot of stuff in a very small package. My goal for this vehicle to run with OEM like drivability including emissions components. This vehicle is primarily a street vehicle and taken to the track a handful of times. This was one of the main reasons why I selected the M800 to command it.
-Joe
-Joe
