Idle Control IGN and FUEL comp
Postby Martin on Wed Aug 12, 2009 5:58 pm
When a car is in idle control the Idle aim error is a small number. As soon as you start accelerating the Idle aim error falls to lets say -500Rpm as it goes out of idle control. When the Car is driven, the Idle aim error stays at that value on the IGN and FUEL comp tables. Will this not cause the Idle IGN and FUEL comps to be used if they dont revert to 0 as soon as its out of idle control?
Re: Idle Control IGN and FUEL comp
Postby John Reed on Thu Aug 13, 2009 12:18 pm
Those trims are only active when under the idle condition (defined in your basic idle settings, usually below 2% throttle).
John Reed
Motec Sales/Install/Tuning/Support
johnreedracing@gmail.com
John Reed
Postby Martin on Thu Aug 13, 2009 3:31 pm
If the Idle Aim Error stays = -500 Does that mean that the table is just ignored when out of idle?
Postby PQatPIT on Thu Aug 13, 2009 9:58 pm
This interests me , too :)
Is there a flag or something that DEFINITELY tells when idle condition is ON and when OFF?
Thank you in advance.
PQatPIT
Postby John Reed on Fri Aug 14, 2009 8:00 am
The idle fuel/ignition trims clear (zero) when the system is no longer under idle control (either due to tps/rpm setting being cleared, etc).
You can view it on your fuel/timing parameter screens.
John Reed
John Reed
Postby Martin on Fri Aug 14, 2009 4:33 pm
Ive tested it, it does clear, but Idle aim stays at the last value before it exits.
Thanks John
