Bosch ABS Wheel Speeds
PostPosted: Fri Aug 01, 2008 2:28 am
by EuroRace
Does anyone have a wire diagram or know the wheel speed output pins on a Bosch ABS unit. # B265 153 259.
Posche # 993 618 125 70. This is a 993 Cup ABS unit. I have been looking & asking all over the globe, but no info available. Thanks.
Eurorace
Re: Bosch ABS Wheel Speeds
PostPosted: Fri Aug 01, 2008 5:42 am
by figgie
Have you tried to contact Bosch directly?
They are usually pretty good at keeping technical specs on hand regardless if it is BMW, Porsche or Mercedez-Benz.
PostPosted: Fri Aug 01, 2008 6:49 am
by EuroRace
I have contacted Bosch, Porsche Motorsport, and Motec USA, but have no help as of yet.
PostPosted: Fri Aug 01, 2008 6:50 am
by uvii
Geoffrey Ring on Rennlist would probably know, as I think he runs one on his 964 race car. Here is his website:
http://www.racetek-engineering.com/
PostPosted: Fri Aug 01, 2008 8:28 am
by Martin
On some bosch pumps, even with different part Nrs these are the speed output pins. On some pumps the "wake-up" (Ign12v) wire is on a different pin. If you want further details on pinouts let me know. I think these might be applicable to your pump aswell, maybe post a picture of the pump and of the connector.
8
10
12
14
Martin Roets
PostPosted: Fri Aug 01, 2008 12:11 pm
by EuroRace
All the pins on the pump go to Power supply, Control unit, Relays. No wheel speed outputs on the pump. I am resonably sure the wheel speed outputs come from the small pins on the control unit.
PostPosted: Sat Aug 02, 2008 3:55 am
by Martin
The pinouts i gave are for Certain bosch ABS pumps. Like the ones found in BMW`s. (those pins are the actual output pins on the ABS pump.
On the bosch pump like the one found on the RX8 pin AA is the Vehicle speed output
PostPosted: Sat Aug 02, 2008 10:45 pm
by EuroRace
I think I found the outputs, it seems like the in the center row of pins, # 40 & # 42 are the wheel speed outputs.
We will test it today & reply.
PostPosted: Sun Aug 03, 2008 9:28 am
by EuroRace
The wheels speed outputs are 40 & 42, works fine. You only get 1 front 1 rear signal.
PostPosted: Thu Aug 14, 2008 2:33 am
by gring
The 996 Cup ABS system has several pins switched from the 996 GT3 street wiring diagram. Call me if you get stuck.
