Injector setup on a M800
I have the following.
4 primary 1600cc PTE Low Impedance injectors (Not sure who the manufacturer is but the specs are below)
043-1600 1600cc Low 2Ω 1.300 1.000 Pintel N/L
4 Secondary 2200CC Siemens Low Impedance Injectors
Coil Resistance: 2.27 Ohms / Low Impedance / Low-Z (ECM peak & hold driver or modifications required)
Static Flow Rate @ 43.5PSI ( 300kPa ) w/Gas: 220 lb/hr = 2433 cc/min
Offset: 0.64ms
Turn on time: 1.5ms
Turn off time: 1.3ms
Connector: Bosch EV1
Series: DEKA 4 ( DEKA IV )
Orifice Type: Single Orifice
Spray Pattern: 10-15 Degree Pencil Cone
Factory fitted with Viton upper and lower o-rings
Currently, I have no idea how to setup injector sizing on the Motec. I would like that to be accurate before I adjust any fuel tables. I have gotten the car started, but I think it was luck. Car runs very nice on the motec too.
I would like to sort out before I continue.
Offset: 0.64ms
Turn on time: 1.5ms
