anti lag - bypass
hello,
maybe someone can help me.
i want to use antilag on our rallycross car. i don't want to open the throttle permanently, so i tried to
install a bypass, that is opened by the m800 if antilag is needed.
the problem is, that all of the 8 outputs are used and i don't know how i can open the valve which should
bring air to the engine.
my question: is the valve only opened when the driver puts his foot from the throttle or is the valve opened when the driver activates antilag with a swith in the cockpit?
i think if the valve is normally opened when the driver activates als it doesn't matter if i open the valve for the air manually without support from the m800. do you agree?
does anyone have a good setup for a racing car with restrictor?
thanks for your help.
regards
regards
