Evo 9 Secondary Air Bypass System (OEM Anti-Lag)
Hi
I have a M800 OEM (version 89 adaptor with 3 connectors) for an Evo 9 JDM which means that I have all the hardware for the Secondary Air Bypass System (SABS).
As I understand it, the SABS allows boost pressure from the intake piping to leak into the exhaust manifold between gear shifts, thereby acting as an anti-lag system - without the harmful bang-bang
I have INJ5 and IGN7 set up as STATUS but I can't figure out how to control it. I know it is linked to the Motec ORB table 2 but I can't figure out the setup.
Can I set it up to just open the SAS solenoid, like in the OEM application?
Thanks in advance.
Regards
Jason
Thanks in advance.
Regards
Jason
