Evo 9 Secondary Air Bypass System (OEM Anti-Lag)
Postby jasonthai on Tue Jul 29, 2008 2:47 pm
Hi
I have a M800 OEM (version 89 adaptor with 3 connectors) for an Evo 9 JDM which means that I have all the hardware for the Secondary Air Bypass System (SABS).
As I understand it, the SABS allows boost pressure from the intake piping to leak into the exhaust manifold between gear shifts, thereby acting as an anti-lag system - without the harmful bang-bang :D
I have INJ5 and IGN7 set up as STATUS but I can't figure out how to control it. I know it is linked to the Motec ORB table 2 but I can't figure out the setup.
Can I set it up to just open the SAS solenoid, like in the OEM application?
Thanks in advance.
Regards
Jason
jasonthai
Re: Evo 9 Secondary Air Bypass System (OEM Anti-Lag)
Postby RossB on Wed Jul 30, 2008 1:15 pm
Hi Jason,
You will need to set the parameters for INJ7, the following:
Selection 31
Logic Polarity 0
Output Mode 0
Flash 0
Flash Rate 0
This will open the by-pass valve when ORB is active.
IGN5 drives the Intercooler spray lamp to show which ORM mode is selected.
