RossB wrote:THe CAN Data is 2 and the Address is 240 for an E888 but I am assuming that you already have this if you are receiving channel data from the E888. This information is in the Help File ("F1" key). What other documentation do you need?
RossB wrote:I have found the problem with the farenheit cal for E888 thermocouple, it starts at 0 instead of 32. You can fix this by changing it on the Input Setup. Select the #83 pre defined calibration, then select the Custom Button and this will allow you to look at and edit the table. You need to change the deg F value so that when input is 0 it is 32. The value at the top of the scale is correct.
RossB wrote:Unfortunately there is no way of adding more than 8 user channels in the M800.
RossB wrote:
Are you using the latest version of ECU Manager? We found a bug in AV6 and AV7 expander inputs which has been fixed and may account for some of the confusion over the channel units you are seeing.
What function are you wanting to use on the expander digital inputs?
Users browsing this forum: Baidu [Spider], Bing [Bot] and 7 guests
