hi,
I am setting a V60 motor on my bike with M800. It has a classic 36-2 scheme, and I use mode 7. The motor revs good at Idle and low revs. As the fuel map is not completed, I didn't tried at revs higher than 4000rpm and high loads.
CRIP is 305°before TDC cylinder 1. It is 120°AFTER TDC cylinder 2.
I read in the help files that during heavy acceleration, the index tooth could be missed.
Will it be a problem to have the index tooth at this position?
I have the sync tooth about 40° before index tooth. In the help, setup menu, it is written that sync pulse should be 180° +/- 70° before the index.
Will it be a problem to have the sync tooth at this position?
Angelo
