M800 Injector operation
Tue Jun 02, 2009 4:23 pm
by Martin
If I set an M800 to have 2 cylinders and 4 coils...will the M800 still fire all 4 coils evenly spaced through a cycle? ( No oddfire tcd`s set)
M
Re: M800 Injector operation
Wed Jun 03, 2009 11:43 am
by RossB
When you configure 2 cylinders you can only configure 2 coils. What are you wanting to do? If you use ignitiion Mode 140 on a 2 cylinder you will have IGN1 and IGN3 firing at the same time and IGN2 and IGN4 firing at the same time. You cannot use the Rotary Split Table (assuming this is for a 4 stroke) but you can use the individual trims and tables to achieve a timing split if required.
