electric wastegate with M800
Wed Oct 16, 2024 6:40 am
by MyRaw
Good morning everyone!
I wanted to know if anyone has managed to use an electric wastegate with M800??
Re: electric wastegate with M800
Wed Oct 16, 2024 9:22 am
by Stephen Dean
Using the Turbosmart "Black Box" controller for the EGate, and sending a PWM signal into the controller from the M800 with give you position control of the gate, but with no real feedback.
You could possibly build some aim tables using the Aux Tables, but this would be something that you would need to develop yourself.
Thu Oct 17, 2024 6:55 am
by cotje
YES! check my post:
https://forum.motec.com.au/viewtopic.php?f=11&t=5661&sid=3651717759cf09d02bc4214d8333f48b&sid=2dff934a576d1b997770d1a4f7583c1e#p25749Did this for the eALV with blackbox and planning to use the second output of the blackbox for the eWastegate. Gives very nice and precise control of the valve opening (with Aux-table as stated by Stephen). I even linked it to another table to be able to enable/disable the behavior (Boost-setting 1 > no eALV, Boost2/3/4 > with eALV).
Beware, these valves need serious power! In my case, controlled by a Motec PDM.
