Page 1 of 2
Idle hunt
PostPosted: Fri May 15, 2009 10:42 pm
by AaronM
I have an idle hunt issue. The engine is a Ford turbo 4L in line six with ford 2 wire pwm idle valve. XF Falcon type. I can get it to idle well in gear but not out of gear and vice versa if I change the normal position etc. I have tried all sorts of proportional and integral gain settings. It gets quite bad when slowing down in gear say 20km/h. Map is consistent as is the injector time. Is there anyone interested in looking at the cal file for me or any advice?
Aaron
Re: Idle hunt
PostPosted: Fri May 15, 2009 11:15 pm
by IJ.
What road speed have you set it to start controlling idle?
Re: Idle hunt
PostPosted: Sat May 16, 2009 10:14 am
by AaronM
It is set to start controlling at 4km/h I have tried 3-6. same result
Re: Idle hunt
PostPosted: Sat May 16, 2009 11:28 pm
by IJ.
Try 12 and see what happens.
Re: Idle hunt
PostPosted: Tue May 19, 2009 5:09 pm
by richie
Aaron,
do you have cold start issues with that idle valve? If not, what is the set up? I am having trouble with my 5.0L windsor. I am assuming it is same as V8 one.
richie
Re: Idle hunt
PostPosted: Tue May 19, 2009 9:51 pm
by AaronM
I have sorted it out now. Cold start is excellent. Use the logger and watch your idle set point against engine speed. Log the idle actuator position as well. You will see the problem pretty quickly. What sort of problems are you experiencing?
Re: Idle hunt
PostPosted: Tue May 19, 2009 10:05 pm
by IJ.
What sorted it?
Re: Idle hunt
PostPosted: Tue May 19, 2009 10:54 pm
by AaronM
I had to add another channel to the idle speed table. It's an auto. I added in gear and out of gear position then setup idle speeds for both positions. Next I setup the idle control 'normal position' for both gear positions as well. Works awesome. Normal position of the pwm actuator is the key here. I can have a look at your Cal if you want, may be able to help.
Re: Idle hunt
PostPosted: Wed May 20, 2009 10:12 am
by IJ.
I use DBW Idle control but had used the Ford valve for a few years before and found it needed some time to get settled on decel with an auto/high stall hence the 12 kph on setting.
Glad you have it sorted now as they can provide many hours of frustration ;)
Re: Idle hunt
PostPosted: Wed May 20, 2009 12:05 pm
by richie
Aaron,
I am running an M800 based on TPS/MAP with a 1993 Ford 5.0L windsor small block. It is more or less a daily driver so am trying to setup the ISC Ford part # E9AZ9F715AA (2 wire) for cold starts without much luck. It operates at 160 Hz square wave & zero signal is minimum duty cycle. I am told duty cycle can be anywhere from 20% to 80% but realistically it operates between 40% to 60%.
When stone cold it takes a fair while to crank - when it catches I need to use throttle to hold at 1200 rpm for 20 - 30 seconds & then it will hold idle for rest of warm up albeit rough. When hot there is absolutely no problem. Seems that if I use throttle it goes to a different table.
I have attached a couple files which may help.
FastHeat_Richardiac.e35
config file
(72 KiB) Downloaded 1224 times
20090401-0659400.ld
log file
(220.25 KiB) Downloaded 1091 times
20090402-0659400.ld
log file
(636.08 KiB) Downloaded 1163 times
Cam is compcam XE276HR Lift in/ex 0.544 dur at 0.050 224 in / 230 exh. LSA 112.
Any ideas anyone?
Richie
