Ref sensor
Thu May 14, 2009 9:07 am
by Jagil
It is possible with M400 configure this trigger wheel:
http://img138.imagevenue.com/img.php?im ... _579lo.JPGThe trigger wheel has 57 teeth, then it has 2 linked teeth and then 1 missed tooth, and i can't find it in "Ref/sync mode".
or should i get a comun 60-2 trigger wheel?
Thank you.
Re: Ref sensor
Thu May 14, 2009 10:08 am
by RossB
This looks similar to the trigger wheel on some Renault engines. It may be possible to make this work using mode 7 or 8 but it would be easier to tell from a scope capture from the sensor.
Re: Ref sensor
Thu May 14, 2009 7:39 pm
by Jagil
The mode 7 and 8 are for two missed, aren“t they?. And this trigger wheel is not so.
In the following scope you can view the cam and crank sensors:
http://img206.imagevenue.com/img.php?im ... 2_92lo.JPGThank you.
Re: Ref sensor
Fri May 15, 2009 9:15 am
by SprinterTRD
If you work out the tooth widths you will find the wheel is 60-2
Re: Ref sensor
Fri May 15, 2009 9:26 am
by RossB
With it wired to the polarity shown on your scope capture Mode 7 should work if you use a falling trigger for both ref and sync.
What engine is this?
Re: Ref sensor
Fri May 15, 2009 3:28 pm
by Martin
I would think it`ll work but you might have to reduce the Tooth ratio slightly from the normal 50%
