Compatible M800 SI Throttle Valves (Diameter: 50 mm)
Hi everyone,
I've come across information suggesting that not all SI throttle valves are compatible with the MoTeC M800. Can someone please clarify the specific requirements? Additionally, could someone provide one or more examples of an SI throttle valve (normally closed) that is compatible with the MoTeC M800 and has a diameter of approximately 50 mm?
Thanks in advance!
Thanks in advance!
