High boost switch
I want to make a high boost switch. I have digital wired to a latched switch so that it is on when grounded. I am going to make boost comp 1 table add 15% to my base boost when i press it.
I am having trouble under input pin setup. I made a new channel under user and called it HI BST. For setup i chose Dig2 input. For calibration i used custom- unitless no decimal place. For the table i used input of 0 to be 0 and input of 1 to be 1.
I then made a table under boost comp 1 to do the same with 15%.
I doesn't seem to work and wonder if there is a better way or proper way to do this?
Thanks!
Thanks!
