Mx00 BAP fuel comp
Mx00 BAP fuel comp
Postby Martin on Tue May 05, 2009 6:37 am
How is this compensation accessed in the Mx00?
M
Re: Mx00 BAP fuel comp
Postby MarkMc on Tue May 05, 2009 9:39 am
Hi Martin,
The BAP comp is automatically called up in the background and is the same as the standard MAP comp (0% comp at 100KPA and -100% comp at 0Kpa). You cannot access this compensation table to change it.
The BAP comp also only starts when there is no MAP channel, turn on the MAP channel and the BAP comp stops. If you have both channels (MAP and BAP) turned on and you want to do a fuel comp based on BAP as well you will need to make it an axis for either Comp 1 or 2.
Postby Martin on Tue May 05, 2009 3:40 pm
Well explained, thanks
Users browsing this forum: Bing [Bot] and 10 guests
