Good morning,
I'm trying to connect a knock motec module onto an M400. the manual says to connect the knock window to inj8...but the M400 only has the option of 4 injectors..What pin can I connect to?
Thank you
Stephen Dean wrote:I have just followed the configuration process as laid out in the SKM Manual using an M400 on my test bench, and all of the functionality is able to be configured, including Injector 8 as the Knock Window.
The ECU Manager does not have the smarts to hide Inputs and Outputs depending on the ECU selected, so the Injectors 5 through to 8 are visible in the Manager, even though they are no active in the ECU.
Stephen Dean wrote:Here it is.
