The most under utilized M800 install ever?
Powering a single injector flow bench
Since the photo's I've switched to a scale accurate to .1g instead of the graduated cylinder. Its run by my M800 and laptop (laptop simulating engine sensors through printer port) I will most likely slowly update this to log everything through the ecu including fuel weight, temp in, temp out, pressure, and dead time (along with all the other obvious injector parameters that are already logged)
My current thinking is a strait gauge and a platform with a bottle on it some simple calibration should be able to turn that into a scale unless anyone has a better idea, i'm really hoping there is a 0-5v scale out there.
