Aux Table Configuration for Variable Frequency
Postby Martin on Wed Apr 29, 2009 8:44 pm
Motec, would it be possible to have the choice of varying Frequency at a fixed duty cycle on an Aux Table?
I would like to use this for driving a Stepper Boost gauge and also an OEM Speed gauge.
Re: Aux Table Configuration for Variable Frequency
Postby Martin on Thu Jul 09, 2009 8:51 pm
Postby MarkMc on Fri Jul 10, 2009 9:37 am
Hi Martin,
This has been a request for quite some time now but no answer as yet from the software guys. I will prompt them again. :)
Postby Martin on Sat Jul 11, 2009 2:25 am
Thanks Mark!
Postby Polux RSV on Tue Jul 14, 2009 8:20 pm
I had the same request. :cry:
I used an aux PWM table and an external small microcontroller. It reads the PWM from the M800, and generate the right freqency with its internal timers, to drive the Marelli Dash. Good results. But should be better if this could be replaced by a simple wire :lol:
Martin, another simpler solution is to generate a variable voltage filtering a PWM. This voltage drives then a LM331 (voltage to frequencer converter, http://www.national.com/ds/LM/LM231.pdf) which generate the right frequency.
Angelo
Polux RSV
Users browsing this forum: No registered users and 30 guests
