Motec M800 with PDM15
Tue Jul 04, 2023 7:46 pm
by ammar.alqisie30
We have a EVO X with M800 ECU and PDM 15, we have an issue with CAN Setup, We need to make the Fans working on PDM related ECT on ecu .
So any idea about the CAN Setup on ECU & PDM .
Re: Motec M800 with PDM15
Wed Jul 05, 2023 10:34 am
The attached PDM file has the M800 receive channels that you need in it, this uses the standard M800 transmit data.
Fri Jul 07, 2023 3:43 pm
by ammar.alqisie30
Thanks Stephen, i got it .
Should we do anything on ecu ( Can Setup ) ?
And how we can activate ALS from keypad ? Keypad connected to PDM, whats the can message ?
Mon Jul 10, 2023 10:17 am
I don't have a setup that I can test with at the moment, but as far as I am aware it is not possible to use CAN switches into the Mx00 series of ECU's.
Tue Jul 11, 2023 5:49 am
by super7
Stephen Dean wrote:I don't have a setup that I can test with at the moment, but as far as I am aware it is not possible to use CAN switches into the Mx00 series of ECU's.
A long shot.
It is not possible to activate an output on the PDM that has been connected to an input on the M800
Tue Jul 11, 2023 10:24 am
That can be done.
Sat Feb 10, 2024 7:10 am
by cotje
If have ORB setup working with the Keypad/CDL/M800 combi. Keypad can send data to the CDL and CDL forwards it to the M800. Some conversions were needed to make it work, but with one key I can now go through ORB off/1/2 settings. Works awesome!
Same for different boost-settings btw!
