Injection ends when changing parameter in ECU manager
I use a stationary research engine equipped with a MoTeC M800 ECU, which controls both injection and ignition at this moment. Recently I've been getting the issue that the injection drops to 0 in reality when changing something while running (IJPU%, ignition timing, ...) but the IJPU table is filled in correctly. The error that keeps appearing is 'Error Inj Max Duty', while the duty cycle is nowhere near 85 % (rather around 12.5%).
It is used on a retrofitted diesel engine, with 5 cylinders running on diesel (so no injectors or ignition via the ECU), with one running on methanol which is being controlled via MoTeC. It has been running successfully for a full week, however it suddenly stopped without any internal changes.
Is there anyone who's had a similar problem? We've tried resetting the ECU, changing the injection timing so it has more time to fully inject, this helped somewhat but not consistently and the same problem kept turning up. Any possibility that the ECU itself is damaged?
We use 12 ohm injectors from Bosch Motorsport (0 280 158 040).
Thanks!
Thanks!
