RPM fluctuations
RPM fluctuations
Postby Dreher7 on Fri Apr 14, 2023 10:59 pm
I am having this RPM fluctuations.. Any idea where or how to stop it ?
The video is in that link: https://youtu.be/wNDbtQ0G-XM
The ECU file:
https://github.com/g4Iv0t4/Motec_HYD/blob/main/Start_test.e35
Any help will be immensely appreciate it !
Dreher7
Re: RPM fluctuations
Postby SprinterTRD on Fri Apr 14, 2023 11:51 pm
Are you getting REF/Sync errors?
Are you using the correct REF/Sync mode for the trigger system you have on the engine?
Postby Dreher7 on Sat Apr 15, 2023 12:31 am
SprinterTRD wrote:Are you getting REF/Sync errors?
The mode I have to set up it is for 2 stroke as this engine haven't got cam sensor. The suggestion was made by Motec Europe. The funny thing is the engine is attached to the dyno engine, and I can see that the engine itself isn't hunting, that means I can see there is no fluctuation in the engine, it is in the software, however I don't know where to look after to try reduce this fluctuations. On top of that, I already run a power curve with the engine, and works well, it has to be something that I can adjust in the software, dont you agree?
Dreher7
Postby SprinterTRD on Mon Apr 24, 2023 5:27 pm
I would reset the maximum RPM display and then run the engine again and see if the rpm you ran it to matches the max rpm captured by the ECU.
IF the max rpm captured by the ECU is a crazy number then you have noise issues getting into the REF sensor.
This could be caused by unshielded REF wiring or noise generated by the ignition system
