I might need your help, as I cant think anything else to do it.
I have a single cylinder engine, with no cam shaft sensor. The engine is not attached in the dyno engine.
The problem that i am facing is:
In the software, the first gauge which shows the RPM, the readings are way too high, looks like is double that what must be, but that is just a guess.
Following the orientation of motec dealer, I have set up the number of cylinder as -1:
Here is my REF/SYNC set up:
I don't know what else I can change, or try to get the RPM readings correctly. The engine has 10 teeth, missing one.
Ref/Sync file:
https://github.com/g4Iv0t4/Motec_HYD/blob/main/firstAttempCrankSensor.rsc2
ECU File:
https://github.com/g4Iv0t4/Motec_HYD/blob/main/First_test_afterAdjust.e35
Any suggestions?
