High v Low Impedence and Lag Time - Motec
Hey Guys,
I'm in the market for some Sard 800cc Injectors to suit 1JZ/2JZ.
I am currently using USDM 550cc Supra Injectors which are Low Impedence, however at peak torque the duty cycle is 80% - hence the upgrade to larger injectors.
Sard make a High Imp and Low Imp injecotr with lag times as follows:
Low Imp - 0.75ms
High Imp - 1.6ms
The injectors are the exact same price for High or Low Imp. High imp injectors can have a better resell value due to their compatibility with the PowerFC and perhaps a stock ECU and piggyback setup such as e-manage ultimate.
Low imp injectors are what every one is raving on about for performance applications, however the new rage in the USA has been Bosch 1000cc high imp injectors - presumably for their better fuel control being high imp?
How important is a Low imp injector in a performance application and would there be any adverse effects in performance and drivability if I was to go for the High Imp version and reset / retune the motec to suit.
Cheers
Costa Tsimiklis
Low Imp - 0.75ms
High Imp - 1.6ms
Cheers
Costa Tsimiklis
