Subaru EJ25(2011) Swapped Impreza WRX STi V8(2004) NO SYNC
I have a Subaru WRX STi V8 USDM (MY2004) Vehicle fitted with a Plug and Play MoTeC M800 (5 Plugs), but the engine is transplanted from a Subaru MY2011 2.5L;
It doesn’t have the front Camshaft (Sync) sensor, only the 2 rear camshaft position sensors
I get a REF Signal on Cranking and RPM, but no SYNC and no REF/SYNC indicator
The two rear Camshaft Position Sensors are of Hall Type 3 Wire
Which one should I use as SYNC and how to wire it into the MoTeC ?
Kindly
Thank You
Kindly
Thank You
