M800: No sensor readings, shows 0 battery volts, yet PC spea
Fresh install of a new M800 on an RB26 Skyline engine. My laptop sees the ecu, and can apparently update firmware OK. However, despite the injectors and coils seeing 12 volts from 2 different and known good batteries, as does the ecu, the "View Sensors" screen show no sensors working, and zero battery volts. Downgrading to earlier software and changing firmware to suit shows 5 battery volts but still zero from all sensors. I can't upgrade the ecu options, either, despite having the passwords. The PC is communicating via a Motec parallel port cable and the CAN BUS into the M800. Loom is a modded stock one, using a loom adaptor between Motec and stock loom plug. Any ideas please?
Only really odd thing is when you initially power up the ecu I see a very brief red single spike waveform move slowly across the engine temp graph, only for it to then disappear completely. The *only* reading I am getting is internal ecu temp. I have tried 3 variations of software, from old to current. I can write new maps to the ecu. The ecu has never been used before.
Thanks for reading.
Thanks for reading.
