Open pins for brake pressure and oil temp
Following a choice to add a brake pressure sensor and potentially an oil temperature sensor to my car I looked into the
Ecu for the used channels and then pin out diagram to try and find a spare way,
Now I think I’m confusing myself but also the Ecu has been used on two cars and potentially the tuner hasn’t cleaned up the unused channels since the changes were made, I say this because I cannot get a match between the outputs and then the pin setup pages one says that pins are allocated and then other says not!
I have looked at the logged data to see if I’m getting readings from the channels to add up what is live and what is not. Would it be safe to “assume” I know that this is dangerous that if the out put say AT3 is shown in digital input functions as gear ign cut but in input setup it doesn’t feature at all on any page and the data has a straight 0 all through the run that it is not used and can be wired for a pressure sensor? To make this a little bit harder all of the ecu plugs have wire in! So it’s not like I can clearly see that it’s an old feature and not used as it is wired in the ecu plug end anyway!
Would it also be safe to say then that if it doesn’t feature in the input pin setup box that it isn’t used currently when running the car and can be changed as desired? And potentially the only pins that are used are in the box with allocated inputs?
Any guidance would be greatly appreciated
Thank you
Thank you
