Ignition switch
Is it possible to receive the ignition switch signal over CAN from the PDM ?
We have a 2 step ignition counter in the PDM.
Just like a normal car.
We are using step 1 to ensure oilpress before we start the engine.
And step 2 to power ignition coil, injectors, and for now the fuel pump.
The power to the ECU is always on, and I want to control the fuel pump from the ECU aux output over CAN as well.
To prime the fuel when entering step 2, and to ensure the pump stops if the engine does.
BR. Brian
BR. Brian
