m400 coil on plug conversion, dwell
Postby gazt00 on Wed Mar 16, 2022 2:26 am
hi, im doing a coil on plug conversion on a lancia delta its running a motec m400 and the customer wants to change from distributor to coil on plug , im stuggling with the dwell time settings, it is using a bosch 0227100211 ignition module and bosch p50 single fire coils, on the bosch website it gives you the values for 16v, 14v, 12v, 10v etc i was wondering how i work out the values in between? below is from the bosch specs.
6v 7.7ms
8v 4.51ms
10v 3.2ms
12v 2.51ms
14v 2.06ms
16v 1.74ms
thanks, Gaz
gazt00
Re: m400 coil on plug conversion, dwell
Postby Stephen Dean on Wed Mar 16, 2022 8:54 am
The ECU will interpolate the dwell times needed for the battery voltages in between the supplied data. Just enter the supplied data into the Dwell Table.
