ignition signal output
I would like to know about Ignition outout signal, How many volts does the ignition signal output normally have?
I checked with the Test Outputs command and measured the signal with an oscilloscope. I found that the IGN1 and IGN2 have a signal output 4 volts. The IGN3 and IGN4 6 volts. Please tell me if it's normal or not.
Please see attach pictures
Thanks in advance.
Thanks in advance.
