Melbourne Tuner for M800
As the subject suggests, I'm looking for a top notch tuner in Melbourne.
I'd also appreciate approximate costs of the following
1) Initial setup - REF/SYNC are there, all the inj and coil outputs have been checked as ok as has the TPS and MAP. So it's now time to set fuel & spark timing/duration and setup for mild boost (7 psi).
7 analog outputs also need to be setup. The motor has a variable intake resonance system, no egr, 8 injectors (4 cyl, not hi-lo), IAC, boost noid, shift indicator etc
Once the motor has a few hours on it
2) Street tune - Basically clean up the initial tune and adjust for 10 psi
3) Strip tune - 2 Bar of boost optimised. 125 HP shot of N2O progressively delivered
I'm sure there will be heaps of suggestions, so to make it easier I'm in the Outer Eastern burbs of Melbourne, the car will be flat topped to and from the tuner (costs per km).
Leaning towards Simon (Nizpro) as he has a good rep for squeezing every last bit out of the M800 but would appreciate a heads up on the cost of this endeavor
Also is there more that I can do statically to reduce the tuneup cost, settings wise?
Cheers
Bazz
Cheers
Bazz
