Coldstart problems with honda K24
Hi Guys,
have a problem with my honda k24 with a m800 ecu.
I often have cold starting problems. During the cranking, the rpm fluctuate between 140 and 320 and then suddenly I briefly comes to 800 rpm and fall out of the cranking table and the start does not work.
here is a short video clip
https://www.youtube.com/watch?v=URB7I8IF0ww
What have i tried so far?
INJ timing higher value
Higher dwell settings
-20 to +15 ignition while cranking
more cranking fuel
less cranking fuel
more TP% while cranking
less TP% while cranking
more first injection
less first injection.
In most cases i have the errors error sync signal and No sync error signal during startup. but i don't think it has anything to do with the failed start. If i have a great hot start, i have the error too and after reset errors it comes never back.
a friend has the same problem with his k20 and motec m800.
Does anyone have any idea why this could be?
more cranking fuel
less cranking fuel
