3x 8 Injectors
I require an ECU for a special engine combination.
The engine in question is a Supercharged V8 in a Tube Frame chassis car.
The ignition is a MSD 44AMP Magneto, so the ECU will not be controlling any Ignition paramaters.
I require the engine to Run 3 sets of Injectors (8).
One set will be required to work at idle (and possibly WOT).
Two sets will be required to work at WOT.
I presume that the only outputs this engine will need will be 24 injector drives?
What inputs will the ECU require?
Regards, Andrew
Regards, Andrew
