M600, Twin NTK and Relay Question
PostPosted: Thu Sep 16, 2021 10:26 am
by pooh_bear
Spent last few weeks drawing out my new wiring diagram.
I've come across an issue i need help with clarifying.
Employing DBW which will be on AUX 1 and AUX 2 outputs.
The data sheet that came with the 57007 sensors says any AUX output is OK for heater -ve.
However, I recently read that the NTK heater circuits won't work unless they're on the high current outputs AUX 1 and AUX 2. And if those outputs taken by DBW i need to use a PWM relay.
1) Is that true?
2) If yes, will one relay be OK?
3) Is the Bosch-style Hella relay suitable? (i'm aware the pinouts are different to normal relays)
4) Wiring - low side output from ECU connects to -VE of relay and +ve to A26?
Thanks!
Re: M600, Twin NTK and Relay Question
PostPosted: Thu Sep 16, 2021 1:21 pm
Where was that information posted?
There is no issue with running the NTK sensors on the other Aux Outputs.
PostPosted: Fri Sep 17, 2021 5:27 am
by pooh_bear
SDean wrote:There is no issue with running the NTK sensors on the other Aux Outputs.
Thanks for quick reply. That's great news - my wiring plans can remain unchanged! :D
SDean wrote:Where was that information posted?
On the Facebook MoTeC Tuning Forum
PostPosted: Fri Sep 17, 2021 12:56 pm
by zarpspeed
From Help
9 : Lambda Sensor Heater Control
Controls the current to the Lambda sensor heater.
This is required for all wide band sensors that connect directly
to the ECU.
Note: The sensor heater should normally be connected to either
Auxiliary Output 1 or 2, however if these are required for
another function such as DBW then another Auxiliary output
or Ignition Output may be used.
Note: Not suitable for the Injector Outputs due to tripping the
short circuit limit when the sensor is cold.
PostPosted: Fri Sep 17, 2021 2:33 pm
That Facebook page is not affiliated or controlled by MoTeC in any manner.
