Ref/ Sync capture - occasional backfiring on crank
I have been tuning and working my way through various issues on a dodge viper gen 2 engine that was already fitted with a Motec M800 ecu. These issues are wide and varied from poor power feeds to awful mapping.
It is now 90% sorted but I am struggling to get a clean and consistent start. Occasionally the engine pops or backfires through the inlet or exhaust. It sometimes does this when running too. I have checked all the physical causes, ht leads, plugs, coils, air leaks etc and the fuel/ignition timing seem ok. I suspect noise on the sync sensor.
Please can someone have a look at my ref/sync capture file and tell me if the noise I am getting is acceptable or likely to be causing issues?
Much appreciated.
Kind regards
Nate
Much appreciated.
Kind regards
Nate
