M400 EGT
M400 EGT
Postby ms_logging on Mon Jun 14, 2021 4:44 am
need an advice. planing to setup 4 EGT sensors on Motec M400.so what i need to buy and what options are available for it ? thanks.
ms_logging
Re: M400 EGT
Postby David Ferguson on Mon Jun 14, 2021 5:24 am
Easy button is to use a MoTeC E888 expander, connect your type-K thermocouples to that, connect it to the M400 via the CAN bus, and configure the EGT inputs to use that.
Otherwise, if you have 4 available analog inputs, you them with an external thermocouple amplifier. I have been happy with products from Exhaust Gas Technologies, like this 4-channel amplifier w/sensors (but they sell parts separately):
https://exhaustgas.com/ProductDetail.as ... &BasketID=
Lastly, there are some other brand lower-cost EGT-to-CAN devices, but you will have to setup their CAN output correctly, and by the time you do that, the E888 is the easier / more supportable option -- it is a lot easier if you have a MoTeC dash where we can more easily handle any CAN input, and then send it on to the M400 (plus log it!).
Re: M400 EGT
Postby ms_logging on Mon Jun 14, 2021 5:52 am
thank you for your reply. looks like E888 is good variant to try. i dont have dash so it is hard to configure? any examples or details ? thanks
ms_logging
Re: M400 EGT
Postby David Ferguson on Mon Jun 14, 2021 8:33 am
It is very easy to configure for EGTs. If you would like to post your M400 calibration, we can add the E888 configuration to give you a starting point.
Your MoTeC dealer (whoever you buy the E888 from) should be able to help with this as well.
Re: M400 EGT
Postby zarpspeed on Tue Jun 15, 2021 1:08 pm
Racegrade TC8 is also an option.
zarpspeed
Users browsing this forum: No registered users and 25 guests
