Yamaha wr450f & M400 Ignition and Ref signal
Hi, I'm putting an m400 on a Yamaha wr450 single cylinder motorcycle engine. the stock ignition was CDI, so i have to switch coils unless i want to keep running a CDI, which i'm not sure if i am or not. i will be spinning the engine up to 10,000 rpm, so do you guys think that CDI is nesssary?
For either CDI or not, what ignition module (or CDI box, what are the differences between all them anyways) would you guys suggest for this engine? also, what coil would you guys use that matches the rest of the system as well?
I noticed that there is a coil/module combo from denso, this sounds like a very economical option that i am interested in, what are you opinions on this coil/module?
Also, if anyone has any experience on having the REF signal so close to the alternator in the flywheel cover, that would also be welcome. I plan on using a Hall sensor and embedding 4 magnets into the flywheel or using the stock variable reluctance sensor and adding teeth to the existing one tooth on the flywheel. Any opinions on this would be very welcome as this is my first motec setup. I have done data acq before, but not the fuel injection side of it. Thanks for your help.
Joshua
Joshua
