Disabling sensors
Disabling sensors
Postby Giltgy on Sun Apr 18, 2021 10:49 am
I need to disable some sensors which I don't have installed. These are showing
up on the diagnostics page, and I believe these need to be cleared before I will
be able to actually have the ecu work. The manual
says this is done by "setting the sensor setup number to zero". Can someone please
explain where I do this in ECU Manager??
Best,
Guil
Giltgy
Re: Disabling sensors
Postby Stephen Dean on Mon Apr 19, 2021 12:00 pm
Hi Guil,
If you go to Adjust | Sensor Setup | Input Setup... this will open the Input Setup window, in this window you can edit the settings for the sensors by double clicking on the sensor that you want to modify.
