Digital Input SW IN
Digital Input SW IN
Postby cotje on Fri Apr 16, 2021 6:43 am
Hi all, can someone explain how the Digital Input Sw In works? I noticed I can use a CAN signal from my ADL to trigger it. On my ADL2-channel I have a PDM-cycle-key programmed for ORB that has a cycled value of 0, 1 or 2.
The Dig Sw In is requiring the following fields that I programmed as follows
Source: 3 (ADL)
Channel: 2 (channel 2 is ORB value)
Lo level: 0
Hi level: 1
The problem is that whatever if use for Lo/Hi-level the Input is always showing status On
May someone can show me an example? TIA!
cotje
Re: Digital Input SW IN
Postby cotje on Fri Apr 16, 2021 7:28 am
Found it while I was posting the question. I had to use the multiplier in the SDL to get 1000/2000 values (mV) in the M800. I also had to change the polarity which resulted in a default=off switch state.
I can now trigger ORB map 1 or 2 from the Keypad>PDM>SDL>M800 :) Awesome technology !!
cotje
