M880 + BRZ GDI Driver
Postby Vlad on Tue Mar 16, 2021 3:46 pm
Hello again, i need a bit of info on this. I have a 22635JB000 direct injection driver from a BRZ, and i want to hook it up to my M880. I've never mapped a DI engine till now, and have a Eco Boost engine liyng around. I will put the engine up on my engine dyno, and start playing around... Dose anyone here have the pinout for the BRZ DI module ? Also, some hints on fuel pressure vs tps or map, any trick to output a timed pwm in relation to crankshaft position, will the pump regulator work with regular pwm? and injection timing would be apreciated! Hope someone can help, thanks!
Vlad Pescaru
Vlad
